how to tighten my blazer's chain
Old Apr 22, 2004 | 09:26 PM
trailblazermudrunner's Avatar
Default how to tighten my blazer's chain
hey i need to no how to tighten my 00 tb's chain helpppp!
Old Apr 22, 2004 | 09:34 PM
bisho12's Avatar
First loosen the two bolts that hold the rear brake around the axle. Then loosen the two on the axle carrier. Then take a puch and place it in the small hole on the rear sproket carrier. Make sure the hole is on the top. Then push the quad forward i think tightens it. If not pull it back it will tighten it. Then leave it tight and tighten up the axle bolts first then the brake bolts after.
If you have a problem let me know. I just did mine last week. Very easy.
Old Apr 22, 2004 | 09:45 PM
what do u mean the bolts to the rear brake?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 22, 2004 | 10:09 PM
waynaferd's Avatar
Look up underneath by the bottom of the rotor. There's two small bolts there, on the axle housing, one behind the other. I think they take either a 7/16 or 1/2 inch wrench.
Old Apr 22, 2004 | 10:12 PM
thewayout420's Avatar
here is a parts breakdown,the bolts are #12 here
Old Apr 22, 2004 | 10:40 PM
so just losen up thoes to bults showen in Text and then wht
Old Apr 24, 2004 | 01:39 PM
waynaferd's Avatar
Then do what bisho12 said. If I weren't busy I'd mosey right over and show ya (I'm in Old Town)....
Old Apr 24, 2004 | 05:51 PM
DGScrambler400's Avatar
have you tightened it yet? You'll get the hang of it, then it will become very easy [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 25, 2004 | 08:25 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
here, this will help
Old Apr 25, 2004 | 06:09 PM
Trailblazinrider's Avatar
Hey, when i had to tighten my chain, i broke 2 puch pins, a screw driver, and a couple of nails. The easy way to do it if you start to break things is just losen the bolts, the ones talked about above, and then take a monkey wrench or a large pair of pliers and turn your back end that way. I dont know what was with my blazer, the guy at the shop had trouble doing it too. If your blazer is anything like mine, save the money and just use a big wrench or pliers.
mrtidy
Feb 3, 2016 05:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
