What are
Old May 18, 2004 | 09:05 PM
rsking45's Avatar
Default What are
There are 2 clear vent lines(?)that run under the light pod into the the hollow steering shaft. they look like they come from under the gas tank.Can anyone tell me what they are ?One has some fuel in it .Is this normal?
Old May 18, 2004 | 09:39 PM
RAJ's Avatar
RAJ
Default What are
They are vent hoses for the gas tank and oil tank....this is so they will not air lock, make sure they are not pinched. They have to let air in both tanks.
Old May 18, 2004 | 10:28 PM
rsking45's Avatar
Default What are
one hose has a little gas in it do you think that is something to worry about?If they are to let air in it seams like their shouldnt be gas in the line Right? This is a 04 sp500
Old May 18, 2004 | 10:38 PM
DGScrambler400's Avatar
Default What are
ntohing to worry about, it may be your overflow, if you gas tank is near full and it is sloshing around, it will just go in the hose and drain out, i have had some leak out of the hose when wheelieing, nothing to worry about
Old May 19, 2004 | 12:15 AM
scrambler123's Avatar
Default What are
I have alos had it leak while wheelying before unfortunately it had no plastic on it at the time so i got the gas all over my face and in my mouth. [img]i/expressions/face-icon-small-disgusted.gif[/img]
