CRANK CASE
Old May 20, 2004 | 11:49 PM
Ricke's Avatar
Default LOOKS.......
Me and a friend are going to attempt to fix my crank case..... does anyone have any pointer on making it easyer or things i should watch out for????
Old May 22, 2004 | 02:57 AM
fishslab's Avatar
What kind of damage do you have on the crank case? Do you have any photos?
Old May 22, 2004 | 10:45 AM
racerX500's Avatar
Yea what kind of damage is on your case? A crack or hole? I have cracked my case before on dirtbikes and a little jb weld fixed it right up.
Old May 22, 2004 | 12:57 PM
Ricke's Avatar
i have a hole in it .... i will try to get a photo up.... but my quad is at a friends being looked at
Old May 22, 2004 | 09:11 PM
scramblered's Avatar
Default CRANK CASE
hummm,there is one spot specialy that need a welded mark to help
maintain the case together,,i should have a pic but in other words,it is right under the engine near the counter balance where the bolts are holdind up,mine was welded all around this area ever since and it make a strong package.i never saw a 400 2 stroke motor craked on the flywheel side,,,generally it break at around the clutch front end or
at the counter balance place,take a look,there is a design pattern down there that is easy to fix with a single welding.
Old May 23, 2004 | 02:54 AM
fishslab's Avatar
Default CRANK CASE
If it has a whole from where a rock or something knocked a whole in it it you can get by with JB Weld or something. Try to ocver th whole wiht some piece of metal and JBweld it over. Welding it would be the best solution though. If you use JBweld or something like it, get the surface real clean. Then rough the are up so the epoxy can adhere better.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
WilliamBos
Sep 22, 2015 04:07 PM
