Best kit for a 250 Trailblazer
Old May 25, 2004 | 06:13 PM
bigjohn88's Avatar
Default Best kit for a 250 Trailblazer
I got a 2000 250 Trailblazer and want more more power what kind of kit would help the best.
Old May 25, 2004 | 06:21 PM
MnFriesen's Avatar
are you like talking a clutch kit or what kind of kit?
Old May 25, 2004 | 06:56 PM
thewayout420's Avatar
the reed conversion kits are the best kits you can get for your trailblazer..hpd and azbadboyz are the ppl do deal with..and welcome to the forums
Old May 25, 2004 | 07:05 PM
ftwflh's Avatar
RcR stage one kit or HPD trail mod kit is great.Both are about the same and come with what you need.RcR has a little better customer service if you call him.
Old May 25, 2004 | 07:30 PM
DGScrambler400's Avatar
i would go with the RcR stage 1 kit click for RcR site
Old May 25, 2004 | 07:56 PM
tbsleeper's Avatar
definetly get the rcr stage 1 kit first. then move on to the reed conversion kit or just get porting.
Old May 25, 2004 | 09:07 PM
x_scrambler3's Avatar
One thing to remember if looking to upgrade later to the reedcage kit you should have the porting done with AZ Bad Boyzz or HPD . I know with AZ Bad Boyzz they porting is differnt then HPD's . So keep that im mind. I know AZ Bad Boyzz dose great work work an good customer service. Good pricing too.
Old May 25, 2004 | 09:57 PM
Predsports500's Avatar
Big John, I just installed a Hot Seat Performance kit in a 2001 Trailblazer for my nephew and it really woke it up....He gained 8mph on the top end and much better low end and midrange acceleration....... The kit he bought had the Hot seat pipe , air box mod , clutch kit - included their primary, secondary spring with helix and weights.....He also bought a new belt.....He spent less than $500 on everything - not bad for the performance gains I saw.....We put it up against a new stock 2004 Red trailblazer with flames and aluminum rims and there is no comparison - the 2001 with the kit was much quicker faster on the top end
Old May 26, 2004 | 03:11 AM
1fastpolaris's Avatar
Bigjohn it all depends on how fast you want to go and the money you want to spend..If you want to be as fast as the 400 go with the reed conversion by AZ BAD BOYZ..Or if you want to blow them away and run with stock banshees do what i did...stroke it...........You won't be dissapointed.
Old May 26, 2004 | 08:38 PM
bigjohn88's Avatar
how loud are ther rcr pipes and how much will they help on the top end?
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
