Trail Blazer Over Heating?
Old Jun 1, 2004 | 01:06 AM
MnFriesen's Avatar
Default Trail Blazer Over Heating?
how come it didnt register my last couple of posts?
Old Jun 1, 2004 | 01:09 AM
splitbumper's Avatar
It was full of gas.
Old Jun 3, 2004 | 01:37 AM
kp's Avatar
kp
I have A 02 Trail Blazer and mine did the same thing I found out that I needed to put a top end in it because the hoter it got the more the cyclinder expanded and I was loosing compression you might cheek the compression
Old Jun 3, 2004 | 04:18 PM
Whuggs1's Avatar
I just checked my compression on our 98 TrailBoss after it over heated. Is 130psi high or low?
Sounds like you are running way to lean, I had the same problem in 100 degree heat out at the dunes and was useing a 200 jet.
Old Jun 3, 2004 | 04:40 PM
  #15
tbsleeper's Avatar
your jetting is really screwed up. when i went from 0 elevation to about 3000 and didnt change jetting the engine was having lots of troubles with over heating. i would wait a few minutes then run it again and it would run for a while. find out what the color of the plug is and we will be able to help
Old Jun 3, 2004 | 07:09 PM
  #16
250Man400's Avatar
from what i see in his pics tmac looks real ugly (even uglyer than bbs jk)[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jun 3, 2004 | 07:19 PM
  #17
tbsleeper's Avatar
haha man i just looked at his pics. u see that pos he rides, if i were him i wouldnt say anything about polaris. but then again guys he just got out of atv rehab[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 6, 2004 | 01:49 AM
  #18
My Trail Blazer is completley stock, can the jetting be off if it is original? The plug is black, but it has three tanks on it, isn't this normal for a two-stroke?
Old Jun 6, 2004 | 02:12 AM
  #19
Redbullssg's Avatar
to rich! If she was just putting along, then I prolly just got loaded up. The jetting can be wrong from factory, depends on where it came from... Check my Galley, at the top there is a link for a Mukuni carb tuning manual . pdf download. THis will help you at the least to figure out how to jet it. Not sure if it uses the same type of carb or not as the 400 and 500!?
Old Jun 6, 2004 | 02:18 AM
  #20
Redbullssg's Avatar
Tmac, ur a moron! What a POS you ride. If you were testing it out, why did you buy it, LMFAO!
