what to buy ?
Old Aug 9, 2000 | 09:45 PM
BlazerBoy99's Avatar
I have a 1999 Polaris Trailblazer for sale for 2,500 theres nothing with it at all the only reason is I have the childish need to be out in front (i'm 14). So if your interested email me at rebelforlife_1999@yahoo.com Thanks
Old Aug 9, 2000 | 09:52 PM
IndyDave's Avatar
BlazerBoy, That's a normal need for you, at 14. It's a childish need for me, I'm almost 38.
Dave
Old Aug 10, 2000 | 12:15 AM
OffRder15's Avatar
Yo Joel,
That's plenty or power. A 335 will be perfect for you. BUT, I suggest that you MUST get the MAGNUM 325 ->4x4. It's a little more $$$, but who cares! If you don't enjoy life while your alive, then you're pretty much screwd. If/when you get stuck with a 2-wheel drive, you will definately whish you went for the 4x4! >PLUS<, the Magnum 325 4x4 also has low range which is a must (for me if I had one) if you ever get caught in a slow going, hard situation, it will save your belt alot. Just my opinion. Just keep in mind the two more features the Mag 325 4x4 has, it will help you make the better decision.
Old Aug 10, 2000 | 10:19 PM
DDGofer's Avatar
One last question and I'll let this topic die.
Has anyone used Sam's Club buying program to buy an ATV. I used the program to buy my pickup and save $8000. Just wondering how good it might be for ATV's.
DD Gofer
Old Aug 10, 2000 | 11:20 PM
  #15
CHICKENman's Avatar
DD
Oh no you won't let it die I have question!!!I see all these guy's saying buy the 335.WHY?Isn't it about the same weight and size as 500 I have friend that bought his wife 335 he has 500 and now they say they wish they had got her the 500.
My better half isn't big by any means and she rides and handles 500sp just fine.I really see no advantage to buying the small engine,any input welcomed I just don't understand reasoning.DD no matter what you say now I would bet that won't be long you'll be hitting the trails and be coming back with stories about how much fun you had just like the rest of us.This is from personal experience and some one that has been getting AARP mail longer than you have. LOL CM
I went to polaris site and got this comparision for the 27LBS difference I'd have the 500sp.
Old Aug 10, 2000 | 11:50 PM
  #16
CHICKENman's Avatar
This is comparison on 335 and 500SP # on left side are 335 and right side 500
Sportsman 335 Comparison
Select the models you'd like to compare.
indicates difference
Sportsman 335 Polaris ModelsSportsman 500
4 Valve, 4 Stroke with counter balance 4-valve, 4-stroke with counter balance
Lubrication
Dry Sump Dry Sump
Oil Capacity
2.25/2.13qts/ltr 2/1.89qts/ltr
Carburetion
34mm-CV Mikuni 34mm-CV Mikuni
Fuel Capacity
3.7/14.2gal/ltr 5.25/19.87gal/ltr
Coolant Capacity
N/A 2.25/2.13qts/ltr
Starting System
Electric with recoil backup Electric with recoil backup
Alternator
200 watts 250watts
Drive System
4-wheel independent shaft 4-wheel independent shaft
Transmission
Automatic PVT (Polaris Variable Transmission) Automatic PVT (Polaris Variable Transmission) with EBS (Engine Braking System)
Gear Range
E-Z shift high/low and reverse E-Z Shaft high/low and reverse
Front Wheel Drive
Thumb-switch engage On-Demand true 4-wheel shaft drive Thumb-switch engage On-Demand true 4 wheel shaft drive
Rear Wheel Drive
Shaft Shaft
Front Suspension Type
MacPherson Strut MacPherson Strut
Front Suspension Travel
6.7/17.0in/cm 6.7/17.0in/cm
Rear Suspension Type
Progressive rate, fully independent w/ anti-roll bar Progressive rate, fully independent w/ anti-roll bar
Rear Suspension Travel
9.5/24.1in/cm 9.5/24.1in/cm
Rear Shock
Two 1.625 in twintube shocks Two 2 in twintube shocks
Front Brakes
Single hydraulic disc Single-lever hydraulic disc
Rear Brakes
Hydraulic rear foot brake Hydraulic rear foot brake
Rear Caliper
Hydraulic, opposed piston caliper Hydraulic, opposed piston caliper
Rear Disc
Fixed disc Fixed disc
Parking Brake
Hydraulic Lock, all wheel Hydraulic Lock, all wheel
Front Tire
23 x 7-10 (5 PSI) 25 x 8-12 (5 PSI)
Rear Tire
24 x 11-10 (5 PSI) 25 x 11-10 (5 PSI)
Wheelbase
50.5/128.3in/cm 50.5/128.3in/cm
Turning Radius (Approximate)
65/165in/cm 65/165in/cm
Dry Weight
670/304lbs/kgs 697/316lbs/kgs
Length
81/205.7in/cm 81/205.7in/cm
Width
46/116.8in/cm 46/116.8in/cm
Height
47/119.4in/cm 47/119.4in/cm
Front Rack Capacity*
90/40.8lbs/kgs 90/40.8lbs/kgs
Rear Rack Capacity*
180/81.6lbs/kgs 180/81.6lbs/kgs
Hitch Towing Capacity*
850/385.6lbs/kgs 1,225/555.6lbs/kgs
Hitch Tongue Capacity*
30/13.6lbs/kgs 35/15.8lbs/kgs
Brake Light
Standard Standard
Handlebar Headlight
1 single beam high 60 watt qtz halogen 1 single beam high 60 watt qtz halogen
Hood Headlight
N/A N/A
Grill Headlight
2 single beam low 27 watt qtz halogen 2 single beam low 27 watt qtz halogen
DC Outlet
Front Receptacle / Rear plug-in acc. Front Receptacle / Rear plug-in acc.
Speedometer / Odometer
Standard Standard
Tripmeter
Standard Standard
High Beam Indicator
Standard Standard
High Temperature Light
Standard Standard
Neutral/Reverse Light
Standard Standard
Hourmeter
Accessory Standard
Ground Clearance
11in -
Cooling
Air cooled w/fan assisted oil cooler Liquid-Cooled
Low Range
Yes -
MSRP (U.S.$)
$5,999 $6,999
Brake System
Hyd. Disc -
Displacement
334cc 499cc
Old Aug 15, 2000 | 08:14 PM
  #17
CHICKENman's Avatar
Nobody ever replyed why 335 over 500? CM
Old Aug 15, 2000 | 09:58 PM
  #18
4man2k's Avatar
You know cob, i think you are rite, the 500 is more economical and that is what i would do. I ride a 450es, i went up against a friend with a Sportsman 500 and rode it, we raced, went mudding, hill climbing, and had a bet who could pull the the most round bails. He beat me in every categlory (i was riding the es), even though i am a better rider. I cant believe the ride of the 500, wow!!! I said some sh*t that i would not buy a polaris, and i was lying to my self. I deleted those posts, and that was the rite thing to do. Screw the Rubicon, i am getting the Sportsman 500 H.O. AKA "the king"!!!! You and Lurch are not like "some"<------(i dont wana start a fight) of the guys here you dont fight with them or use say **** like my quad is better than yours or my brand is better than ur brand.
Old Aug 17, 2000 | 12:07 AM
  #19
CHICKENman's Avatar
I'd like to hear from 335 owner and see what the reasoning is behind that purchase over 500.CM
