700 EFI Idle
Old Jun 28, 2004 | 02:12 PM
wickedwackedjuggalo's Avatar
Default 700 EFI Idle
I was just wondering what everyones idles at? my is idling and 820 witch seems to be low. is it low or am
i just used to a 500
Thanks
GIB
Old Jun 28, 2004 | 02:33 PM
polaris5610's Avatar
It should be around 1150RPM, that is a little low........
Old Jun 29, 2004 | 07:52 AM
Kuntry's Avatar
1180ish!
Old Jul 2, 2004 | 12:25 PM
Well i was talking to a guy that has the same machine and his idle is the same. Could it be the elevation? Or should i take it in to my polaris dealer
Old Jul 5, 2004 | 08:25 PM
Diesel3247's Avatar
i had the same problem this weekend.....it ideals real low like in the 700-800. i am pissed..... the second big problem is the fuel line that runs from the pump to the fuel rail....it just rubbed a hole in the hose from the frame...that was not much longer after the idle went to hell.....
Diesel3247's Avatar
also....what did the dealer say was the problem for the low idle.....i am taking my in this week......
Old Jul 5, 2004 | 08:56 PM
BigBadScrambler's Avatar
A hole in your fuel line would cause a low idle because it is not gettign the fuel pressure it needs
Old Jul 5, 2004 | 09:14 PM
Marko's Avatar
Mine idle around 1180 too.
Old Jul 6, 2004 | 01:28 AM
PlatinumDogg's Avatar
Is there anything bad about a low idol...and why do u guys want higher idols....im just wondering
Sean
Old Jul 6, 2004 | 09:42 PM
mtpockets's Avatar
wickedwackedjuggalo, just wondering if you ever brought your EFI to the Dealer to have the idle adjusted?
(i read your original post from June28th)
...just wondering!
-MT[img]i/expressions/face-icon-small-smile.gif[/img]
