best 2 stoke oil??
#22
KLOTZ the way to go,normal techniplate 50:1,r-50 is is too pig rich for a polaris,to tell you true,those engine didn'T need high racing oil
cauze they don't rev as much the oil was tested for,just normal synthetic
from polaris will work great,but i do prefer klotz smell when ever
i run.
i would like to see a cylinder and pistons after some tank of amsoil dominator stuff into a scrammy 400,that could be stick!
i run.
#24
amsoil nothin better, klotz is good but if you look at tests amsoil is better, less wear, less deposits, runs cooler, running coller is better as 2 strokes heat up they loose power so running cooler is better
#25
the "test" are done by amsoil themself so it can turn out to be true in this case,it is like polaris said before releasing the predator by their speed chart comparing others sport quad,sure it outpaced everyone out there.
