Counter balance and gear case oil change
Does anyone know how often these two oils should be replaced. I can not find it it the owners manual.
Also how do you change the counter balance oil, i could not find that in the owners manual either. I know you use 10W40 but where do you put it?
thanks
thanks
Polaris fill holes are a drag to fill, being so small. I looked and looked for a funnel that was small enough at the tip to fit the holes, but never found one. Finally, I found a turkey baster style battery checker in my basement, cut off the first three inches, and inserted it in the end of a flexible tranny funnel, it works like a dream.
KimSJoh
14
Jul 18, 2015 07:20 PM
