welding to frame
Old Jul 29, 2004 | 05:52 PM
polarisman3's Avatar
Default welding to frame
well i was going to weld a plate to the frame of my '03 sp 600 and was just wondering what you need to do before you weld to the frame like disconnect the battery or mabey you shouldnt do it at all either, i dont know.....using a wire feed welder if that matters with up to 130 amps.....any ideas??????
Old Jul 29, 2004 | 06:02 PM
BigBadScrambler's Avatar
On automobiles, you always disconnect the battery. I would do the same on the quad just to be safe. You don't want to be frying your Pod. Also, be sure to prep the area good before you start. Other than that, you should be ready to go.
Old Jul 29, 2004 | 06:13 PM
so you dont think that electricity should be able to travel backwards threw grounds connected to the frame or will all of the electricity go thew the ground cable on the welder if you have it close to were you are welding...thanks for reply
Old Jul 29, 2004 | 06:15 PM
maddog56's Avatar
You had better disconnect the battery and cdi or you'll be buying a new cdi. I was at a race once and had to weld my frame. I was in such a hurry I forgot to disconnect the cdi, and ended up having to shell out the bucks for a new one.
Prep the area too, and be very careful with the steel tubing. Its realtively thin and you can make a mess in a hurry.
Old Jul 29, 2004 | 06:17 PM
The electricty should just go back through the ground cable. I would still disconnect the battery though
Old Jul 29, 2004 | 09:50 PM
ok i will disconnect the battery both pos and neg.....and also the cdi which is under the handle bars right? anything else...just hope it wouldnt hurt the stator any....
Old Jul 29, 2004 | 11:56 PM
maddog56's Avatar
The stator only has current when its spinning, you should be fine on that.
Old Jul 30, 2004 | 04:40 AM
rescuediver's Avatar
I agree with maddog. I've welded on my frame and the stator was fine. As a matter of fact, I'll be welding on it tomorrow[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 30, 2004 | 04:43 AM
WISTECH's Avatar
Ive welded on hundreds of vehicles and atvs and almost never diconnect anything. No electrical device has ever had a problem. Just keep your ground clamp as close as possible to the weld itself so there is no chance of current running through any wires.
Old Jul 30, 2004 | 06:55 AM
Hairback357's Avatar
I have welded the frames on all of my quads and never disconnected anything. I wouldn't worry about it.
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
bigred20653
Oct 2, 2015 10:05 AM
greg86hd
Sep 16, 2015 12:32 AM
