RCR stage one kit
Old Aug 1, 2004 | 01:12 PM
montecarlo97's Avatar
Default RCR stage one kit
I gonna try and put my stage 1 kit on today and was wondering how hard it is to get the carb off to change the jet?
Also is there any tips or tricks I should know?
I don't have a service manual, but I downloaded and printed the exploded views of the clutch and carb from polaris.
Any help would be great.
Thanks,
Troy
Old Aug 1, 2004 | 01:37 PM
thewayout420's Avatar
its really simple,give it a try and if you have questions then come and ask[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 1, 2004 | 02:53 PM
DGpolaris2346's Avatar
Yea its easy just unscrew the float bowl drain screw and the main jet is right there.
Old Aug 2, 2004 | 05:22 AM
I got everything on alright, seems to have a lot more speed.
The only thing I don't like is it seems a little sluggish on the bottom end. You have to get rolling a little(5mph) before it really picks up, and you have to give it a lot more throttle to get it moving.
I don't know if my wife will like it because we do a lot of trail riding in and out of creeks, small hills etc.
I was wondering, if I put the stock spring back in the clutch, would that get it rolling a little sooner?
Also the pipe keeps the pullstart boot from going over the hole. Is this normal or did I do something wrong.
Thanks for the help
Old Aug 2, 2004 | 06:49 AM
jimmypsp700's Avatar
With the heavier spring the rpms need to be higher before it launches, mines quick off the line. The t-handle should clear without a problem especially if its length wise front to back, check the location of the pipe / silencer as someone else had a clearance problem similar not too long ago.
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
Huntingdeer
Aug 23, 2015 12:06 AM
