weird scrambler problem
#20
I know some of the older PWK carbs had a brass rod in the bowl.check and make sure you don't have this brass rod sticking out in the bowl of the carb.What was happening was when you would run at full throttle the carb would run out of gas.If yours is in there ,just grab it with a pair if pliers and pull it out.
