Something really bad has happeaned! :(
"somehow came loose"...haha, stuff works its way loose when you ride, that is why you should check over your bolts after every ride or two. I am not bashing you, I have had bolts come loose too that I was just too lazy to check. It sucks about where the bolt has ended up though, hope u can get it out without too much work. Good luck man.
The crankcase is sealed. Only anything can get into it would be through the intake or exhaust ports. correct me if I'm wrong [img]i/expressions/face-icon-small-confused.gif[/img]
Chances are the nut may be in the duct rattling against the case.
i think u mght be right whuggs cuz do u guys know how air enters that plastic duct thing up by the light and goes into teh crank to cool it?? i think theres a lil channel around the inside to cool it...am i right?? cuz if i am i can make a magnet or something and stick it in.
#15
it is on a trailblazer!! i pulled it out and stuck a magnet thing in but no luck i think maybe if i find a smaller one.
but is it just like a channel around the crank to cool it??
#18
lol,there isnt a crankcase air duct,that air duct that goes to the case is for the clutch,take your clutch cover off like the others mentioned and it should be right there,or you might have to take the primary off like ced said..
