sportsman light modifications
Old Aug 4, 2004 | 02:31 PM
beaker69's Avatar
Default sportsman light modifications
Hello,
I have a 2004 1/2 sportsman 700. Does anyone know how to do the light modification to get all 3 lights going at the same time?
Thanks[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 4, 2004 | 02:34 PM
yaK's Avatar
yaK
Welcome to the fourms! If you do a search on it in the fourm here you will find all you need to know!
Old Aug 4, 2004 | 05:32 PM
Gordeaux's Avatar
Beaker, I have an extra one if you want it, $8.00.
Old Aug 4, 2004 | 05:44 PM
silverbullet2005's Avatar
whats going on, did you have to buy the light modification kit online or are there stores around that will sell them.
Old Aug 4, 2004 | 06:53 PM
Gordeaux's Avatar
I bought mine online. I ordered extra for friends, but the tight a$$es backed out. I have 2 extras.
Old Aug 15, 2004 | 02:25 AM
marcski's Avatar
what to buy for $8 ?? a relay or couple of diodes is all it takes
Old Aug 15, 2004 | 12:56 PM
NBsportsman's Avatar
I read somewhere that if you put the switch between high and low beam all three lights will work. I tried this last night and it works great. A little tricky to get the switch to stay there but once you get it your good to go...
Old May 18, 2005 | 11:15 AM
atvmudman's Avatar
I found that you can purchase these light modification kits on ebay for $7.50 or less. I bought one and installed it which only took a few minutes. Some of them even offer free shipping. Here is a link to one of the listings from the seller I used.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Old May 18, 2005 | 02:46 PM
Thevolkp's Avatar
I know a lot of people have put on the sportsman light modification, but haven't heard if it caused any problems. I purchased a kit about a month ago and haven't installed it yet. My Sportsman is only 2 months old. The last thing I want is to burn the existing switch out or cause another problem. Should I be concerned or should I just install it?
Thanks.
Old May 18, 2005 | 03:37 PM
xcrider's Avatar
If you have the relay version of the modification (see my pitcures for the wiring diagram) you won't have any problem putting to much current through the headlight switch. If you use the diode version the current for all three lights must go through the headlight switch and IMO you run the risk of burning it out. A replacement switch is about $60, so do what ever your comfortable with.
