Trail BLazer vs 250 ex
Originally posted by: 1fastpolaris
Does it sputter at full throttle? If not I would try raising the clip on the needle one notch and see how that works. Hope that helps.
#16
Originally posted by: tbscrammy500
it doees not sputter at full throttle, it sounds very smooth at full throttle. And im not running rich, the plug looks fine.
#17
They both are good machines, just depends on what you want. The EX is smaller and easier to throw around (350 compared to 480). It wheelies easy and jumps good, it also has the driveshaft instead of chain. They are pretty close in the speed department, we have drag raced them. They both are good hillclimbers but the TB does it easier. I weigh a little over 210 lbs and either one will haul me up and down some pretty good hills. The TB has better suspension and rides much better, the auto is nice in general but not as good if you want to wheelie or for taking off on jumps. Both machines are reliable, the only thing we ever had to do on the TB was chain and sprockets, the Honda needed a new coil once. The TB is a little cheaper and has better stock tires. I wouldn't hesitate to buy either one.
Alex Rodak
Sep 11, 2015 11:42 PM
craacker
Sep 9, 2015 04:32 AM
