Throttle Response
Old Aug 6, 2004 | 04:14 PM
bigjohn88's Avatar
Default Throttle Response
Are there any cheap mods to get a better throttle response out of a trailblazer. When you hit the gas it stalls for just a second and then it will go. How could you fix this?
Old Aug 6, 2004 | 04:42 PM
thewayout420's Avatar
a pipe and a clutch kit will make a big difference.
Old Aug 6, 2004 | 06:06 PM
bigjohn88's Avatar
i have the rcr stage 1 low to mid range kit on it and it still does have good throttle response.
Old Aug 6, 2004 | 06:22 PM
dunerdogg's Avatar
yeah go with a pipe and clutch kit and if you want your motor to rev quicker and faster go ahead and lighten your flywheel its helps quite a bit I definatly recomend you have dennis shotwell do it (AZ BAD BOYZ!)
Austin
Old Aug 7, 2004 | 09:06 AM
tbscrammy500's Avatar
yeh i have the same problem and have been looking into the rcr stage 1 kit.
Old Aug 7, 2004 | 01:50 PM
radblazer400's Avatar
Once you get a pipe and clutch kit lighten the fly wheel. I can't believe the difference it made. I could never ride wheelies. I'd mash the throttle to get the front end up and when I'd let up a little on the gas the front end would drop. Now the throttle response is so fast that I can get back into the gas to hold it up.
Old Aug 7, 2004 | 03:22 PM
scramblered's Avatar
it can be a poor belt shape or and bad dialed clutch,,,
Old Aug 7, 2004 | 05:05 PM
DGpolaris2346's Avatar
If you dont want to spend 325 bucks then just get a new primary spring and that will only set you back about 20 bucks.
2quiker
Mar 22, 2022 08:36 PM
Customer Service #1
May 15, 2020 08:46 AM
hueby
Nov 6, 2015 11:34 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
