scrambler transmission
Old Aug 7, 2004 | 11:55 PM
Tazz's Avatar
Default scrambler transmission
Has anyone done or now of anyone that swaped out the transmission for an explorer tranny for the low range? I have a 99 500HO and would like to know is this can be done or am I better of getting rid og this one and buying a polaris 500ho sports man? Thanks damian
Old Aug 8, 2004 | 12:07 AM
Whitedog's Avatar
Its been done, I think theres just some linkage issues. I do beleve that a fella with Berts dirt works has one done. on a 400
Try and do a search.
Old Aug 8, 2004 | 01:11 AM
scrambler123's Avatar
anyone have any ideas why my tranny would make noise when i roll the bike in neutral?? it is full of gearcase lube.
Old Aug 8, 2004 | 01:17 AM
BigBadScrambler's Avatar
It had been done. There are a few on the forums that have done it. 425Xpedition did it (although I havent seen him in awhile). I do believe that the shifter needs to be modified though
Old Aug 8, 2004 | 09:38 AM
ftwflh's Avatar
You can do it but you need to change shiftersand linkages along wth the tranny. Scrambler123 check your drive chain and if thats ok pull your clutch cover,put it in gear turn the secondary clutch and see how much slack is in the internal chain.It could be this chain making your noise.
Old Aug 8, 2004 | 11:56 AM
thanks ftwflh
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
