Breaking Secondary Buttons
Old Aug 11, 2004 | 04:49 PM
thewayout420's Avatar
Default Breaking Secondary Buttons
one you have the clutch apart all you need is a torx bit to get the buttons out..
Old Aug 11, 2004 | 08:04 PM
BeltDrive's Avatar
Yea 420 is right all you need is a torx to get the old ones out. I also put in the hpd hd buttons. If you go that rout you will need to do some grinding and drilling to mount the new buttons. In my case I had to also file the new buttons so they would seat right.
Old Aug 12, 2004 | 11:01 AM
SethL11's Avatar
What are the differences between HPD's buttons and the stock buttons that would require you to grind down HPD's?
Old Aug 12, 2004 | 11:15 AM
CED's Avatar
CED
The screws for the HPD buttons go thru the housing from the back side.The grinding is very minimal.
Old Aug 12, 2004 | 11:32 AM
  #15
SethL11's Avatar
Are the '02 trailblazers' secondary any different from that of the '03 model, because if you go to partsland.com, the diagram for the '03 secondary looks identical to the drive clutch
Old Aug 16, 2004 | 11:40 AM
  #16
tbsleeper's Avatar
hwo do u tell if ur buttons are worn or broke without taking the secondary apart???
Lucas Bohanan
Sep 29, 2015 01:16 AM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
