SP335 Speedo not working
Old Aug 21, 2000 | 12:16 PM
blades's Avatar
My speedometer/odometer stopped working on my 2000 SP335. Hourmeter works. Is there anything I can check myself before taking in for service?
Thanks.
Old Aug 21, 2000 | 01:36 PM
jigginjack's Avatar
Blades: Not much you can do. I experienced the same problem on my Magnum. Sometimes the key chain gets caught between the gas tank on a tight turn. This turns your key to "almost off" which is the cause of your spedometer not working. This is a common problem with Polaris. Make sure you get a new assembly and if you have a key chain on your key. Take it off.
Old Aug 21, 2000 | 03:35 PM
ChopperBill's Avatar
SP335's speedometers have the old style mechanical drive. On the left rear of the trans case you will see the speedo drive, Remove the three nuts that sucure it to the housing. You will probably find that the short drive key(1 in. long) is broke. Check and make sure that the whole drive isnt froze up (mine was).Don't forget to take out the broken piece in the drive assy' before you replace the short drive key.
Old Aug 21, 2000 | 03:41 PM
bowtiepu's Avatar
i have an expedition 425,i noticed while riding yesterday that the speedometer quit,i wasnt too far from the end of the trail so i just loaded it up and took it home..i noticed when i unloaded it that it had started working again..any ideas? im thinking maybe a loose connection which ill check for before next ride,but wasnt sure what it could be..any help is apreciated,thanks in advance
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
