01 scrambler fox shock on a 01 trailblazer?
so u think the long travel wouldnt fit under?? u may be right bigbad our 99 400's shock looks identical to my shock but it just dont have the reservoir but my shock is alot better for some reason?? maybe the 99 needs a rebuild
Correct big bad
I have actually done both Trailblazer and scrambler.
We own a 2001 Trailblazer 250 and I BOLTED ON A PRE-2000 fox shock w/reserevoir.
(Note: Scramber Fox shocks have reservoir, Sport Fox shocks do not have reservoir)
On my 99 scrambler I wanted long travel rear suspension, You must change the swing arm also.
The mounting point on the swing arm is farther back, allowing clearance to the cross brace on the frame behind the shock. ( I guess you could CUT AND WELD)
If you have a pre-2000 scrambler/sport or a pre-2003 trailblazer, they are NOT long travel rear suspension
If you want to convert them to long travel it will be necessary to change both the shock and the swing arm from a 2000 or newer scrambler or 03 or newer trailblazer.
Just as a note: To change the swing arm you must have a 2 3/4" socket to remove and install the bolts hoding the swing arm to the frame. Channel Locks will not work.
Would a post 2000 scrambler shock work on a postr 2003 Trailblazer? I have a 2005 trailblazer 250 and I am looking to replace/upgrade the rear suspension as well. Since aftermarket rear suspension is unavailable I was hoping to find something from another bike.
Here's the atvs that shared the same shock as a 2003.
Usage : 7042142
Year Product Model Assembly
2004 ATV A04BA25CA TRAIL BLAZER SWING ARM/SHOCK MOUNTING - A04BA25CA/CB (4986208620B07)
2004 ATV A04BG50AA SCRAMBLER 500 4X4 SWING ARM/SHOCK MOUNTING - A04BG50AA/FA (4986228622C07)
2003 ATV TRAIL BLAZER 250 SWING ARM/SHOCK MOUNTING - A03BA25CA/CB (4975037503B07)
Here's the ones that share the same shock as your 2005 Trail Blazer 250.
Usage : 7042319
2009 ATV TRAIL BLAZER 330 SUSPENSION, REAR SHOCK - A09BA32AA (49ATVSHOCKRR7042319)
2009 ATV SCRAMBLER 500 4X4 SUSPENSION, REAR SHOCK - A09BG50AA (49ATVSHOCKRR7042319)
2008 ATV TRAIL BLAZER 330 SUSPENSION, REAR SHOCK - A08BA32AA (49ATVSHOCKRR7042319)
2008 ATV SCRAMBLER 500 4X4 SUSPENSION, REAR SHOCK - A08BG50AA (49ATVSHOCKRR7042319)
2008 ATV SCRAMBLER 500 4X4 INTL SUSPENSION, REAR SHOCK - A08BG50FA (49ATVSHOCKRR7042319)
2007 ATV SCRAMBLER 500 4X4 SWING ARM/SHOCK MOUNTING - A07BG50AA/FA (4999201549920154C07)
2006 ATV TRAIL BLAZER SWING ARM/SHOCK MOUNTING - A06BA25CA (4999201499920149B07)
2006 ATV SCRAMBLER 500 4X4 SWING ARM/SHOCK MOUNTING - A06BG50AA/FA (4999201549920154C07)
2005 ATV TRAIL BLAZER SWING ARM/SHOCK MOUNTING - A05BA25CA/CB (4994739473B07)
2005 ATV SCRAMBLER 500 4X4 SWING ARM/SHOCK MOUNTING - A05BG50AA/FA (4994789478C07)
Don't know if this helps,but any other shock you would have to match eye to eye length to see if it would fit.As far as a Fox shock working,don't know. Cheapest oem stock shock for your 05 I've found was at Cycle Parts Warehouse for 96 bucks.
Usage : 7042142
Usage : 7042319
exmotocrosser
Sep 13, 2019 06:12 AM
