Carburetor
Old Aug 23, 2000 | 01:51 PM
wolp's Avatar
I have a 99 Scrambler 400 with Hot Seat 12:1 head, RCR Porting, Wiseco Piston .040" over, Shaved Flywheel, Delta Reeds, K&N with Outerwear cover, and run 93 Octane fuel mixed 32:1 pre-mix with oil injector removed. I have the RCR airbox mod but always run with the lid on. The stock 34mm carb is still on the bike but it has been bored to 35.5mm by RCR. I have a 40 pilot, stock needle set on middle position, and 360 main. I adjust air screw every ride. I ride at 1000 feet and outside temperature last time I tested jetting was 85 degrees. My concern is the 40 pilot seems rich and the 360 main doesn't seem lean it doesn't seem to matter how large I go on the main I can't get the bike to skip. The plug color is light brown so that seems fine. If I engage the choke while wide open the bike will cut out a little indicating it is finally rich.
My question is could the reason I can't get the main to go rich is because with the mods I have the carburetor can't flow enough fuel no matter what size main I go to?
Also, there are a few others on this forum with similar mods. Any feedback as to what pilot jet size you are running would be appreciated. I think I can get away with a 35 and have done some testing in hot weather but I am afraid of what the winter may bring although I never ride in temps. lower than 40 degrees.
Old Aug 23, 2000 | 04:24 PM
dailyrider's Avatar
That carb is ok. But the carb you want to put on is a Keihn 39mm PWK carb. It will give the best power for the $$$. It is easy to jet and works great. And you won't beleive the gas mpg.Just ask how many Polaris owners have that carb on there modified Polaris 400's.
Ask the Editor
Sep 14, 2015 08:57 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
WesTech
11
Aug 11, 2015 07:55 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
