Need some expert help..with Sp 500 HO..
Old Sep 13, 2004 | 11:36 AM
Mj4all2use's Avatar
Default Need some expert help..with Sp 500 HO..
I have a 2000 sportsman 500 HO..I had a short (wiring harness from battery running under frame chaffed)
which ruined my speedometer.. I now have no AWD. The local dealer wants 349 plus tax which will run me over 400.. Is there a way to jump the wires so that awd will run off the awd switch?? Also any ideas on where to pick up a used speedo..Thanks in advance
Old Sep 13, 2004 | 10:01 PM
rmkcac700's Avatar
put 12 volts to the grey wire and ground the brown.
Old Sep 13, 2004 | 11:13 PM
Mj4all2use's Avatar
Thanks all for the replies..Will let you know how I make out..Now will I still have on demand AWD or will this be change that?
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Elkaholic
Sep 6, 2015 02:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
rjacree
Aug 3, 2015 10:21 AM
carolinabomb
Jul 26, 2015 08:40 AM
