predator owner ?'s
Old Sep 17, 2004 | 06:07 PM
NJRaptor419's Avatar
Default predator owner ?'s
Originally posted by: Bradracer18
but I also don't think you can run red line water wetter in the winter(cold temps)......
Check out engine ice. I believe that will mix with antifreeze..
Old Sep 17, 2004 | 08:00 PM
speeeedy's Avatar
engine ice is only used by itself. no outher additives.
Old Sep 18, 2004 | 12:07 AM
17's Avatar
17
Just to let your brother know, if he really want to ride hard, he better get his frame gusseted. I have gone through 3 frames in less than one year. One cracked under warranty, one I rolled off a 12 foot burm - no doubt that cracked, and the last one was last weekend in an MX race. The carb and air intake system just fell off on a double - the bottom frame was cracked completely into on each side.
All three breaks were at different places on the frames - just be careful -
Preds can't take the hard jumps and ground. Their great for sand and trail riding unless you get it gusseted or have an after market frame.
my bike is custom rebuilt and suspension set by a pro suspension guy -- And I'm still having trouble with the frames
Old Oct 6, 2004 | 01:29 AM
trailrider500's Avatar
very true.......added heat can be a problem too......red line water wetter, and air scoops make a huge difference......but I also don't think you can run red line water wetter in the winter(cold temps)......TR500......do you have any inline coolers?? I was thinking about getting one or two, or making myself a set, but I didn't know if anyone had tried them yet or not.
Long Time since i have posted been really busy.
Brad i have inline coolers i got them off ebay for $14 each, they seem to help they are the bigger ones (25fin) i think you can see them in some of my photos.
Old Oct 6, 2004 | 01:39 AM
  #15
Bradracer18's Avatar
Man tr500, you haven't been on in a long time.....all you really missed was making fun of hozed in a recent post.....where he claims to be stalking you at your home....lol.....
Thanks for the reply......I think I'll try and get some......
Old Oct 6, 2004 | 10:46 AM
  #16
predatorracer's Avatar
If you use engine ice you do not have to mix it with anything, it is premixed. The inline coolers do help.
As for slip ons I have had the white bros e series, it is a very good system, I have changed mine to a curtis sparks and like it better.
Air intakes, I have used a k&n drop in filter with 5 one inch vents, a set up similar to the rath racing one, and a filter clamped on to the carb. I like the filter clamped on the carb best.
Old Oct 26, 2004 | 03:11 PM
  #17
Mikes700sp's Avatar
I haven't done the airbox mods yet, I will be doing the intake/exhaust all at once. Rath and Nichols are the best two places to go. Rath build's their own headpipe to go with the WB e series. And nichols further updates it and the carb. 13 tooth is too much gear reduction and almost eliminates 1st. 38 or 39 rear works great and you will climb any hill out there. I gotta agree with the sand stars, great turning with really good straightline bite. Stay away from the water pools though, the soft quicksand will stop you really quick, broke my collar bone last week, it hit the bars and bend the stearing stem, but the frame is still straight. Call Rath with any questions, his wife typically answers and helps you with different setups, he races the pred both mx and tt.
Old Nov 8, 2004 | 11:02 PM
  #18
predator5's Avatar
Depends on the type of riding you do in the dunes. Do you want to hook up, or are you wanting a huge roosts? I have an 03 predator and I use GPC Sand Sharks and I hook up like none other. A budy of mine likes to roost so he uses Maxxis Rooster Straight Blade they still hook up but not as well as a V bladed sand tire
Predator5
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
Ahtatu
Sep 28, 2015 12:14 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
