1994 2x4 300 help
Old Oct 3, 2004 | 03:59 PM
jets371's Avatar
Default 1994 2x4 300 help
Hi everyone brand new to the site hope my answers can be found here.
This is what is going on had the 300 rebuilt it came back ran great (bad head gasket among other things) they went through with a complete rebuild then I took it out to land o lakes state forest trails found some water that came up to bout the racks and it started fouling out plugs turned out air box wasn't tight now it won't start all togather went through carb 4 times nothing it has spark it gets fuel but no fuel is being let to the engine wont even flood plug is dry but no firing unless you squirt gas with a bottle into the carb what might be the problem??? All help greatly appreciated thanx!
Old Oct 4, 2004 | 12:41 AM
BigBadScrambler's Avatar
Have you check the fuel lines themselfs? How about the fuel filter? Take the fuel line off the carb and see if you get fuel coming out of it. If you do, then it is most likely something in the carb. Try draining the carb and cleaning out the jets. You may have a clogged one
And Welcome to the forums[img]i/expressions/face-icon-small-happy.gif[/img]
Barnsnelbon
Sep 27, 2015 03:07 AM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
Polarisman1123
Aug 13, 2015 08:13 AM
Stirling
Aug 11, 2015 07:23 AM
