polaris oil info
Old Oct 6, 2004 | 11:49 AM
braveops's Avatar
Default polaris oil info
i came across this thought it might help
You can use the following instead of Polaris brand oil.
2004 Polaris Sportsman 500 H.O.
Engine Oil: Amsoil AFF, 2 quarts
Front Diff: Amsoil TGR, 4 ounces
Transmission: Amsoil TCC, 1 quart
Drive Hubs: Amsoil STL, approximately 2 ounces per hub (I put it in with a syringe and seal the drain plug threads with Permatex PN 59214. Clean the threads on the plug and drain hole with a Q-tip and isopropyl alcohol before reassembly with the Permatex.)
Amsoil Formula 4-Stroke OW-40 (AFF) = Polaris 0W-40 Premium Synthetic
Amsoil Series 2000 Synthetic Chaincase Lube (TCC) = Polaris Synthetic Gearcase Lubricant (AGL)
Amsoil Series 2000 75W-90 Synthetic Gear Oil (TGR) = Polaris Front Gearcase Fluid
Amsoil Shock Therapy Light (STL) = Polaris Premium Demand Drive Hub Fluid
Amsoil SDF13 Super Duty Oil Filter = Polaris PN 3084963
Filters for All Polaris's except 700.
NAPA: 1358
WIX : 51358
FRAM 6017A
Purolator: ML16819
AC: 2057
Old Oct 6, 2004 | 12:14 PM
BigBadScrambler's Avatar
I use the Amsoil in my engine and trans. You can use any good syn. 75W-90 gear oil in the front diff. And I use Mobil 1 Syn ATF in the hubs. During storage I put Mobil 1 0W-40 Syn oil in. Its cheaper than Amsoil so I can change it in the spring then run Amsoil during riding season
Old Oct 6, 2004 | 10:44 PM
polaris5610's Avatar
NAPA: 1358
WIX : 51358
FRAM 6017A
Purolator: ML16819
AC: 2057
Thanks for the info![img]i/expressions/face-icon-small-smile.gif[/img]
toonces
Oct 16, 2019 12:11 PM
GregM
Mar 6, 2018 06:53 AM
xbin87116
Jul 13, 2015 02:10 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
