what significants does the 2-1/4 load of a spring have on clutching?
I'm speaking of the primary clutch, I am looking at two different springs that are identical except one has a 87 2-1/4 load and one has a 91 2-1/4 load. what would be the benefits/tradeoff of this? I've never heard it mentioned before.
I was under the impression that the engagement was controled by 2.5? thats the first number usually listed. If what you say is right then neither spring will work..........ok now you have me worried, I could have swarn the spring rate at 2.5 contoled engagement rpm.
Shift RPM or "shift out speed" is the rpms where the weight force overcomes the spring pressure and starts moving the primary together. The reason they have to specify them at certain installed heights is because the weight of the weights (how many grams), the tension of the secondary, and clutch alignment can also affect when the shift occurs.
Njrider1230
07-29-2023 05:16 AM
