Scrambler 500 Rear Brakes???
Old Oct 12, 2004 | 02:23 PM
AirWarrior's Avatar
Default Scrambler 500 Rear Brakes???
Are there any other Scrambler owners out there that have found their rear brakes to be pretty weak? I have a 2004 Scrambler and find that the rear brakes offer minimal braking power at best. Does anyone know why this is?
Old Oct 12, 2004 | 05:13 PM
BigBadScrambler's Avatar
I would be hard pressed to say that mine work at all[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img] Tried bleeding them many times with a professional bleeding kit and it still did nothing. Im thinking I either have an air leak somewhere, bad master cylinder, or a bad caliper. Something I am going to have to tear apart this winter. But, for you, I would start with bleeding them a couple of times
Old Oct 12, 2004 | 05:23 PM
97RamSST's Avatar
Yeah, mine do seem to be pretty weak. Only after bleeding them and getting new pads is able to lock up the rear wheels. One reason I think is that our Scramblers just eat right through rear pads, like sand is getting in there and just grinding them down very quickly. I just bleed them and keep the pads fresh before we go on a big trip and it works good, but I it is just kind of a hassle.
Old Oct 12, 2004 | 07:42 PM
AirWarrior's Avatar
Thanks for the feedback guys. However my brakes were weak rigth out of the show room, from day one. SO I don't think its just normal wear and tear. I think it may just be poor design. I've heard other complaints about this too.
Old Oct 12, 2004 | 07:59 PM
Try bleeding them a few times and see if it helps
Old Oct 12, 2004 | 08:02 PM
Ridinghard's Avatar
I have put a little over 100 miles on my 05' and the brakes have been perfect. Like anything though there are bad apples out of every basket, and you may have gotten one. Not sure when you got it, but I'd go back to the dealer, they may not have done a good job assembling it too.
Old Oct 13, 2004 | 01:33 AM
jimmypsp700's Avatar
I agree, bleed them a few times and when needed replace with quality pads (they wear quickly).
They should be able to lock up on soft pack and gravel. Polaris intended the foot brake only as a back up, use sparingly and only as needed.
Old Oct 13, 2004 | 06:00 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
do a search under 'scrambler' and 'brakes' in the polaris forum
this topic has been covered many times before
the rear brake setup on a scrammy isnt a good one in my opinion
Old Oct 16, 2004 | 01:27 AM
ROLLaris's Avatar
The rear brakes on my '00 scram are useless as well. You can stomp the pedal flat and it barely slows, let alone actually stopping the thing. Oddly enough, I still need to replace the pads every now and then. The price of the pads isn't even worth the stopping power they (barely) offer. Poor design is my guess. I just use the lever
Old Oct 16, 2004 | 01:44 AM
DGpolaris2346's Avatar
I get my brake pads for free. The only way i can lock up the rears on pavement is to pull the brake lever and step on the rear brake pedal at the same time.
