removing front on 2004.05 SP 500 H.O
Old Oct 13, 2004 | 10:50 PM
ekazmer's Avatar
Default removing front on 2004.05 SP 500 H.O
I am trying to figure how to remove the from off the plastic part under the light.
i took off the plastic rail on the front but i am afraid to bend and break the plastic looks fragil./
do i need to remove the medal part under the rack on the light?
any hel would be great full
Old Oct 13, 2004 | 10:53 PM
CincyScrambler's Avatar
well u assume that you are talking about the hood, if so remove the rack and it should come out. dont be afraid of breaking the plastic the stuff will almost bend in half before it breaks.
Old Oct 13, 2004 | 11:13 PM
upnort's Avatar
There are 2 tabs at top that go under pod, 2 metal spring clips about 2/3 way down and a tab on bottem under where took rack off. There is no gentle way to remove it. As stated it is quite flexible although I have broken off the lower tab on mine (lil temper tantrum mostly). If you do get it off without a scuff you done well.
JackTheKing
Jul 14, 2015 09:09 PM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
