93 350 L4x4
Old Oct 15, 2004 | 02:21 PM
noone's Avatar
Default 93 350 L4x4
Hey guys I just want to see if anyone else had this problem and how to resolve it if so. When going forward and I switch to 4wd this pulls great, however when I take it out of 4wd i get a very bad pull to the right and have to back up and run it a little to make it work normal again, could this be a axle not coming out? Or could it be an issue with the brakes? Any ideas?
Thanks,
Patrick
Old Oct 15, 2004 | 03:36 PM
Cancat's Avatar
Default 93 350 L4x4
Change the fluid in your hubs, one side is not disengaging, so it is either out of fluid, has old fluid, or has thick gear lube in it.
Old Oct 15, 2004 | 09:08 PM
noone's Avatar
Default 93 350 L4x4
umm well there is something that i didnt know. So I guess the caps in the center have that in them right? I have axles I thought that they were greased that way, I didnt know that the hub itsself had to be greased. What kind of grease or oil would be in those hubs? Thanks for the info. Greatly appreciated.
Patrick
Old Oct 18, 2004 | 09:08 AM
Cancat's Avatar
Default 93 350 L4x4
You can use Polaris Hub oil, or Synthetic Automatic Transmission Fluid, do not use anything thicker than that or the 4x4 will not work in the cold.
CanCat
Old Oct 18, 2004 | 11:14 AM
noone's Avatar
Default 93 350 L4x4
Thanks for all the info, I will make sure to try that.
Patrick
