reverse override mod question
Old Oct 16, 2004 | 12:38 PM
silverbullet2005's Avatar
Default reverse override mod question
I made and installed the reverse override mod kit mentioned on the forums which consists of a four pin 12volt relay wired to the factory speedo harness. I installed the mod and it works great other than not being able to press the yellow override button to change from rpm to odo to trip. has anyone done this mod and gotten the buttom to work to change the display on the guage pod? I may just keep the mod installed and cut the wires I made and insert connectors on each wire that way I can use the mod for winter months while plowing and disconnect the wires I made during the off season. sounds good but was hoping someone had a suggestion to allow me to change the display while the mod is connected. let me/us know if you have experienced this.
Njrider1230
Jul 29, 2023 05:16 AM
SyTye
Sep 11, 2015 02:45 PM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Schneider
Jul 24, 2015 05:05 PM
