High Octane Fuel for Scrambler 400
Old Oct 25, 2004 | 10:31 PM
USMCaviator's Avatar
Default High Octane Fuel for Scrambler 400
I was wondering if I could run Aviation gasoline 100 oct. Low Lead (100LL) its cleaner and burns hotter, however it does have lead in it. Can I run this through my Scrammy 400 4X4? I know the pro's use high octane, usually from 110-130, but they mix oil with it, will my oil-injection be sufficiant with 100LL? I have also heard people mixing Jet A Fuel in the gasoline, is this a possibility? I just done't want to burn it up or anything, so I thought I'd ask you all to make sure.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 25, 2004 | 10:44 PM
Doctorturbo's Avatar
GOT BOOST!
You won't have any problems, have fun. Don't mix Jet A with your gasoline, bad idea.
Old Oct 26, 2004 | 12:43 AM
maddog56's Avatar
Jet fuel, bad idea.
Av gas, you need to jet for it, its not a gas and go.
Unless you are running higher compression than stock, you wont see any performance gains.
Read the octane thread in this forum.
Old Oct 26, 2004 | 01:12 AM
OneBadPolaris440's Avatar
Do you have any mods dont to it? ..... If you dont have much done to it, it probably wont be worth spending the extra money for av gas .... I run 110 in mine and money goes out the door really quick ...
Old Oct 26, 2004 | 12:19 PM
Hillclimber's Avatar
What is everyone running for octane in their 400 with a 12-1 dome. We have 91 here in Vegas. My hearing isn't that good anymore so I mix 1 gal of 100 to 3 gal of 91. Which is a pain because if you run out you can not just stop anywhere and buy the 100 to mix with. Has anyone had any problems with just straight 91. I think that most of you back east have 92 instead of 91 don't you?
Old Oct 26, 2004 | 12:50 PM
Bradracer18's Avatar
I have never really heard of running this av gas(other than in the post running around here somewhere).........we all run VP fuel through ours.........Higher octane isn't always power either, it usually doesn't hurt power, but sometimes doesn't increase it either.......it does seem to burn cleaner though.
Old Oct 26, 2004 | 03:15 PM
scramblered's Avatar
i run 100 LL av gas and it run great,jetting is easy and don't have any
problems related to it.
Old Oct 26, 2004 | 06:27 PM
Sparky660's Avatar
To add a little something, higher octane fuel does not burn hotter it actualy burns cooler.
Old Oct 26, 2004 | 06:38 PM
AZhighRIDER's Avatar
I burn 110 & 114 mixed with a little octane booster...it works gr8, i dont think id ever burn jet fuel though..
Old Oct 26, 2004 | 06:43 PM
maddog56's Avatar
Throw away your octane booster, you are wasting your money.
