replacement winch cable?
Old Oct 28, 2004 | 09:50 PM
20045SP500HO's Avatar
Default replacement winch cable?
i looked in the "rope" winch replacement cable and stainless steel cable, i two guys on ebay selling them will not return my email questions. Any one know of a good place to get a replacement winch cable? How has the "rope" cable worked for you?
Old Oct 28, 2004 | 09:56 PM
sigarms229's Avatar
I put AMSTEEL Blue on my winch a few months ago. So far so good but I've only used it once to pull out a buddies quad. I like the fact that it doesnt really flat spot the way cable can but you do have to be carefull not to have something sharp rub against it. I'll have a better review after winter using it with my plow.
Old Oct 28, 2004 | 09:59 PM
where did u get it from?
Old Oct 28, 2004 | 10:26 PM
sigarms229's Avatar
Sorry forgot to mention, ebay. Got it from this guy, probably one of the one's you tried to contact. All went well with the transaction for me.
http://cgi.ebay.com/ebaymotors/ws/eB...497533277&rd=1
Old Oct 28, 2004 | 11:01 PM
silverbullet2005's Avatar
I would get a factory replacement cable from the manufacturer, if you need a warn cable I have seen them in the cabelas catalog for about 40 bucks.
Old Oct 28, 2004 | 11:39 PM
naturalite's Avatar
I've heard of the synthetic ropes befor. I hear thy are great. stronger and lighter, but you do have to watch for sharp objects though.
Old Oct 29, 2004 | 10:18 AM
scarabrick's Avatar
I use amsteel all the time for rigging props at work.
I also have it as tow rope in my truck and sportsman/scrambler.
You can call patti at Desert rigging (702)798-5559 here in las vegas and she'll hook you up.
You can put more amount(length) on the same drum. Also you can go with a smaller dia. rope but more strengh than the same size cable.
Rick Borba
Old Oct 29, 2004 | 10:53 AM
LDouglasLJr's Avatar
I've been using the "rope" now for just about a year. I got it during the middle of the winter season last year and it held up great. Not to mention I've also used to for pulling downed trees up over a hill side so I could use the firewood for my father in-law. So far the "rope" isn't showing any signs of wear really. I would recommend it to anyone and whenever this one wears out I'll certainly replace it with another one. I did however change from to roller head to the smooth fairlead. IT was recommended and probably better as when looking at the rope while winching I guess it's possible the rope could slip between the rollers and break but don't know. I got my rope from ebay but got the hawse fairlead from another site. http://www.okoffroad.com/stuff-winchrope-atv.htm They also have the rope listed as well.
Old Oct 29, 2004 | 12:51 PM
yaK's Avatar
yaK
since I use my winch alot[lots of muskeg] I found that it was too much of a pain to have so much wire on[50'] so i cut it down to 20' and have lots of webing to get the further distances. It seemed that to get it to wind up perfectly took along time, and if I didnt wind it up good it got crushed when putting a load on it. Now its all good...I may even go with jus 15 ' on there in the future.
Old Oct 29, 2004 | 02:24 PM
I have two winches ... one of front and one rear, cause i never seam to have enough cable [img]i/expressions/face-icon-small-smile.gif[/img]
toonces
Oct 19, 2015 02:21 AM
Schneider
Jul 24, 2015 05:05 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
