kimpex brand hot grips?
Old Nov 1, 2004 | 08:20 PM
badazzpred's Avatar
Default kimpex brand hot grips?
I am possibly looking into the kimpex hot grips the style that slides between the handlebar and the grip they say they have a rating of 25 watts on low and 35 watts on hi with an off switch and that they will work on most 12 volts systems has anyone installed this type of hot grip on a sport qaud and if so have you had problems? thanks
Old Nov 2, 2004 | 01:10 AM
NBsportsman's Avatar
Kimpex have been making heated hand and thumb warmers for years and are great products. I've put them on my sleds years ago and have them on my Sportsman now with no problems......
Old Nov 2, 2004 | 06:18 PM
badazzpred's Avatar
Are yours the grips themselves or just the elements?..........
Old Nov 2, 2004 | 10:57 PM
I have the elements on my sportsman but have used the hot grips in the past on older sleds. If you look in my pictures, the one with the GPS, you can see the two switches on the pod, one for the handwarmers the other for the thumb warmer. Easy install, just heat up the grips, pull them off, clean the bar with alcohol,peal the backing off the elements and stick them on. Spray a little soapy water in the grip and on the element and pop the grip back on. Get the thumb warmer too, no good to have warm hands--cold thumb. This time of year I always have the warmers on low, great too if you happen to get your hands wet......
Old Nov 3, 2004 | 01:36 AM
badazzpred's Avatar
Well thanks to your feedback I think I will be ordering myself a pair. Also thanks for the helpful advice on the install. That is what fellow riders are all about............................................. ......... thanks again.
Old Nov 3, 2004 | 01:52 PM
Bradracer18's Avatar
good luck badazzpred.........haven't talked to you in a while, where ya been?? Have you done anything to that pred as far as performance yet??
Old Nov 3, 2004 | 06:24 PM
badazzpred's Avatar
yeah changed out the sprockets, put a pipe on it, rejetted the carb, cut the airbox open and installed a k&n panel filter and 5 uni filters thats about it I dont need to go any faster Its fast enough for me....................................
wendal
Sep 7, 2019 06:46 AM
EIF
Apr 20, 2017 07:15 PM
fredrikrosen
Oct 29, 2016 07:56 PM
fredrikrosen
Sep 28, 2015 09:58 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
