A polaris with front suspension like a 250r!?!?
Old 11-04-2004, 12:25 PM
Troyer23J's Avatar
Default A polaris with front suspension like a 250r!?!?
From Nacs Racing. It a PEP rebuildable one. I have to weld a tab to bolt it to, but it works good. Well, i haven't ridden with it yet, but just sitting it works good.
Old 11-04-2004, 06:34 PM
mudmaster250's Avatar
how hard would it be to mod a 250R frame to accept the polaris motor and tranny? what was involed in putting the 250R front end on your scrammy?
Old 11-04-2004, 07:15 PM
Troyer23J's Avatar
Doing what I did doesnt seem all that hard. But once you start, you run into alot of problems. I just looked at the two frames, decided where I thought they would go together, then I cut them and started fitting. Went through over a dozen grinding wheels getting things to fit right.
I dont know how hard it would be to make the motor and tranny go into an R frame. I have the back half of mine, I may check to see how hard it would be. Not that its usable, just to see. I know you would have to fab motor mounts and tranny mounts, Wouldnt have that large flate plate for mounts on the tranny like the polaris does. Well, I guess you could cut them out of the polaris frame and weld them in. That would take care of the bottom motor mount too.... Then you would just need to make a front and top mount. That would also have the swingarm mounted. I am sure a new shock mount would be needed too. Ya know, that may have been an easier way to go. I still have a scrammy frame, and the back of an R frame, I will check it out and maybe make something up. I was planning to save the scrammy frame to possibly do this project again, but maybe I will go the other way with this one.
Old 11-04-2004, 10:57 PM
Racerman89's Avatar
Hey right now i have a polaris magnum 500, i was looking for a new exhaust system for it. it already has a K and N on it. i was wondering if a scrambler exhaust system would work on it. and if i also would have to get a jet kit for it to then. thanx with any info
  #15
Old 11-07-2004, 08:06 PM
Kahnman's Avatar
Well John, I found this site! I am going to call on the HPd Quad and sell mine to get it. I'll let you know how it goes.
  #16
Old 11-07-2004, 09:38 PM
Troyer23J's Avatar
KAHNMAN!
Good luck, Keep me posted.
I just put up some new pics, check them out.
Kahnman is the guy whose quad got me inspired to do mine.
  #17
Old 11-07-2004, 11:22 PM
Kahnman's Avatar
Looks great! I will let you know as soon as I can!
  #18
Old 11-08-2004, 12:47 AM
Whitedog's Avatar
Very, very nice! Troyer. What did you do to the engine and tranny? Ceramic coat?
  #19
Old 11-08-2004, 12:53 AM
u stole my question whitedog. how did u get that thing so shiny?!?!?!?!?!?!?!
  #20
Old 11-08-2004, 07:17 AM
Jibrille's Avatar
Honestly, and I am not trying to hate on this whole thing, but what are the advantages of having a scrambler engine in a 250R frame, rather then a big bore 250R engine in its original chassis?
Quick Reply: A polaris with front suspension like a 250r!?!?
