My CHAIN SNAPPED:(
Old Nov 14, 2004 | 08:58 PM
  #31
tyler711's Avatar
Default My CHAIN SNAPPED:(
Is it weird for the chain to have tight and looses spots? i know it is supposed to do it a little, but when i tightened mine today, it can be taught and really tight on one part, but have almost two inches of slack somewhere else. normal? it makes a clunking noise every few feet (every chain revolution i think) any ideas? TIA
Old Nov 14, 2004 | 09:39 PM
  #32
ftwflh's Avatar
Soiunds like you are in need of a new chain.
Old Nov 15, 2004 | 09:27 AM
  #33
Bradracer18's Avatar
Yes, oil that sucker a lot, almost every ride. It sounds like your chain is junk.
tbsleeper........I would fix the play in your swing arm(by the bolts) by either tightening them up, or replacing the little plastic washers, or the bushings........otherwise you could break a chain like I did, or even worse, a case.......
I was also running quite a bit of hp(probably close to 55-60) and running mx/xc with a sport.......probably not a good idea........
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
