predator power
Old Dec 20, 2004 | 12:03 PM
  #21
omahapredator's Avatar
Default predator power
i had both mods done to mine when i went with my big bore.....it has to do wiith machining the internal parts ...making it a smooth bore milling the needle...there's alot of stuff he does and it is almost impossible to do yourself unless you have a TON of tools and access to a machine shop!! it is worth it makes the stock carb flow ALOT better!!! will produce better #'s to the edelbrock and almost any other aftermarket carb...
Old Dec 23, 2004 | 02:02 PM
  #22
DuneMe's Avatar
Omaha:
What bore are you running?
Any stroke?
Who did the work?
Know anyone that has had Falicon do their engine?
Any HP #'s?
Thanks
Old Dec 23, 2004 | 02:24 PM
  #23
i'm runninng a 558cc bore and stock stroke with ported and flowed head, oversized valves and 3 angle valve job, and 13.5:1 compresion......nicholas cycle did the work....hasn't been running right since, in process of getting her done and will have dyno numbers soon!!!
doug nicholas has a 627 falicon in one of his preds also has a 574 stroker too....haven't rode either yet myself but hopefully i will when i go pick up my cams!!!
Old Dec 23, 2004 | 03:46 PM
  #24
Bradracer18's Avatar
Daryl Rath is also running one of Doug's falcion 627cc motors.........he won a few races(all that he raced with that motor) near the end of the tt circuit.
2quiker
Mar 22, 2022 08:36 PM
byronman
Sep 6, 2015 06:34 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
