shock adjustments on a predator from stock settings
Old Nov 22, 2004 | 07:05 PM
alaballer's Avatar
Default shock adjustments on a predator from stock settings
just gotta 04' predator and the suspension is very stiff on it. I know they are adjustable can anyone give me some tips on how to soften the shocks on this puppy
Old Nov 22, 2004 | 07:10 PM
Heapster's Avatar
Don't know what you weigh, but yes the shocks come set very stiff............
Loosen up the front preloads a good 1/4 from where they are now, soften up the rear shock preload the same, put your rear compression ressie **** on 1, 2, or 3, and get a quicker rebound by adjusting the rear shock rebound at the bottom of the shock so the rear end doesn't pack up.
The ***** are there to turn, fiddle with them and dial in the suspension to your riding style and local terrain.
Old Nov 22, 2004 | 07:12 PM
Bradracer18's Avatar
loosen up the front lock nut, and spin the front springs down a bit.......to your liking. On the rear, I like my resivor set at 1, and I also like to loosen up the rear spring a bit.........I turned the dampener(at the bottom of the shock, red ****).......I don't remember which way though, but about 1/2 way from where it is to where it stops turning.......towards the softer side.......
Firefighter400
Oct 8, 2022 06:38 PM
Bratman2
Aug 6, 2022 01:42 AM
slowgsxr97
Mar 18, 2022 03:40 AM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
