Swaw Bar Quick Disconnect
Old Dec 4, 2004 | 12:26 PM
Backinthesaddleagain's Avatar
Default Swaw Bar Quick Disconnect
Is there a kit that allows you to do this on Sportsmans without a lot screwing around???
I don't mind an installtion process........but once it's done I definately want the "Quick Change" type of deal.......preferably without any tools but I would guess that's probably asking too much.
Thanks, Bob
Old Dec 4, 2004 | 01:07 PM
20045SP500HO's Avatar
There's a guy on ebay that sells them. I have one you can check out my pics, it's very easy to remove and place back on, even when on the trail.
Old Dec 4, 2004 | 06:06 PM
Thank you Chris.........That is EXACTLY what I had in mind........even better than I expected relative to easy of use as well (from what I can tell).
Does it basically work by simply pulling the cotter pins and removing the two vertical connector pins between the A-arm and the sway bar on both sides??? Would you say it can be done on the trail easily??? I'm thinking that uneven terrain would put tension/compression on them so you'ld need to do the change out on flat/even ground.
BTW.......Great pictures!!! and a very nice job outfitting your machine.
Bob
Old Dec 4, 2004 | 06:57 PM
SPORTSMAN70003's Avatar
I also have one and you pull 2 pins to take off very easy. It's only for 1 side and I think it should be level when taking off and putting on to make it easier. Great product[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 4, 2004 | 07:00 PM
Oh yea take a look at my pics I have a close up of it.
Old Dec 4, 2004 | 08:23 PM
Thanks [img]i/expressions/face-icon-small-smile.gif[/img]
You only need it on one side (side the left side, away from the muffer).
Getting it on and off:
1. Your right BOTH tires must be level to get it on and off.
2. You can have too much weigh on the rear to get it on and off ... I loaded my machine with a 200lbs of stuff with it off and had to remove most of it to get the sway bar back on.
Other than the above two points i found i can get it on and off in just a couple of mins. But most of the time, i ride without it ... It rides so much better.
Old Dec 4, 2004 | 10:42 PM
Thanks guys
'SPORTSMAN70003'.......Your machine is awesome too!
Both you guys are making me get visions in my head that my squeaky tight wallet is taking exception to.
I have to say though that this mod is an absolute no brainer.[img]i/expressions/face-icon-small-wink.gif[/img]
Bob
Old Dec 4, 2004 | 11:05 PM
Thanks, also make sure you don't ride any faster than 30 mph with it unhooked. I got on mine the other day after a ride and took off wide open and almost lost it in a curve.
Old Dec 4, 2004 | 11:18 PM
Thanks for the heads up........I kinda figured corning with any speed might be an issue.
BTW......I really like your headliner picture. Do you have a close up of THAT one???[img]i/expressions/face-icon-small-tongue.gif[/img] LOL
Old Dec 4, 2004 | 11:24 PM
LOL [img]i/expressions/face-icon-small-happy.gif[/img] Only in my dreams[img]i/expressions/face-icon-small-tongue.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
rockinkgin
Sep 25, 2015 01:52 PM
Rooky
Sep 9, 2015 03:16 AM
