Tire upgrade #2
Old Dec 12, 2004 | 08:42 PM
bucknduck's Avatar
Default Tire upgrade #2
Ok, If I'm going to need spacers to keep stock rims so I can run the Mud lite 26x9x12 on the front of my 2004.5 Polaris Sportsman 500HO, and there is some probability of rubbing from the 26x12x12 on the back, If I were to run with an aftermarket rim such as the ITP, what size (offset) would I need to run to get me out of trouble? The stock rims are 12x6 (4+2) for the front and 12x8 (3+5) for the back. If I go with aftermarket rims, will I still need to run a spacer for the front? Where is the best place online to buy an aftermarket rim.
Old Dec 12, 2004 | 08:48 PM
2manytoys's Avatar
You should not rub anything with 26" tires. My brother inlaw has 26" swampers on his 600 and they dont rub.
Old Dec 12, 2004 | 11:51 PM
elkbow's Avatar
you won't rub on the rear and you can't get different offsets on the ITP's....you will need the spacer on the front of the '04 to run 26x9-12's....don't need much room....although I did just talk with someone that said that the 26x9-12 didn't rub on the front of their '04....maybe just get them in and try them and then order the spacer if you need it....
Old Dec 12, 2004 | 11:55 PM
jefffoxsr's Avatar
Does the 2005 need a spacer in the front for the 26x9x12 Mudlite Dave?
Old Dec 13, 2004 | 12:04 AM
elkbow's Avatar
Jeff, No spacers needed for the 2005 running 26x9-12's or 27x9-12's....
dave
Old Dec 13, 2004 | 12:06 AM
jefffoxsr's Avatar
Thanks for the info.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
