k&n filter
Old Dec 18, 2004 | 10:01 AM
jmcasm11's Avatar
Default k&n filter
i just rebuilt my 97 sportsman 500 but i have a small problem. the exhaust pipe is glowing red. i know that it is running lean but why?
i bought this used and it has a k&n air filter on it. i do not believe the the guy rejeted the carb. would the filter and no rejeting of the carb. give me the same results as a leaking intake or cracked boot? he gave me the filter box with the original filter in the box.
Old Dec 18, 2004 | 10:26 AM
RAJ's Avatar
RAJ
Default k&n filter
Did he drill some holes in the air box? If not I don't think that would be your problem. I just got done working on a Raptor the the header pipe was also glowing...I know I had the jeting right so I sprayed some carb cleaner around the carb boots....one of the boots had a small slit. This fixed the problem. Try that to see if you have any air leaks.
Old Dec 18, 2004 | 11:18 AM
jmcasm11's Avatar
Default k&n filter
i put a brand new air box on so that is not it . i try some carb. cleaner like you suggested. thanks for the feed back.
Old Dec 18, 2004 | 12:59 PM
Sean99TJ's Avatar
Default k&n filter
Sounds like an air leak on the intake side. check all the fasteners and gaskets
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
