need help
Old Dec 21, 2004 | 11:45 AM
dailyrider's Avatar
Default need help
If you look on the left side of the transmission you will see a bolt sticking out of the tranz up against the frame. You want to loosen the nut and screw the bolt into the tranz. Then take a 3/4 wrench and unscrew the plug out of the tranz. this will drain the fluid. Then you take off the right cover next to the floor board. You will see a plug on the top of where the output shaft comes out of the tranz to the front axle. Take that out and you will put I think it is 18 oz of polaris AGL fluid in it. I hope this helps
AZ BAD BOYZ (Dennis)
Old Dec 21, 2004 | 11:54 AM
thewayout420's Avatar
Default need help
im pretty sure its 11oz's dennis[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 21, 2004 | 08:27 PM
besmallz's Avatar
Default need help
thank u daily rider now i can ride this winter. im sort of new to the polaris deal so ill be askin more questions.thanks alot
Old Dec 22, 2004 | 12:45 AM
besmallz's Avatar
Default need help
o yea is there anythign else i can use instead of polaris agl fluid because my closes polaris dealer is in new jersey and that ain't very close
Old Dec 22, 2004 | 01:31 AM
  #15
spyder6's Avatar
Default need help
maybe learn to stop typing like a 12 year old AOL'er?
aside from the sarcasim, you can order the fluids online from PurePolaris - www.purepolaris.com, its under maintnence I belive.
Old Dec 22, 2004 | 04:40 PM
  #16
besmallz's Avatar
Default need help
maybe if u new how old i was maybe u wonder y i type like that.
all aside from that thank u
Old Dec 22, 2004 | 05:10 PM
  #17
mtpockets's Avatar
Default need help
he's new to the forum, sounds young, is asking for help, uses words like "please" and "thank-you" so let's not diss him.
thanks.
sincerely,
MTPockets
