riding in the cold
riding in the cold
Dose, anyone ride in the cold, and if so did you have to re-jet the carb from the factor setting... I am having troble with my new pred ,, I live in wisconsin and the thing stalls out when I run it in the cold the dealer told me the factor jetting is for 40degress and up today it is 22degress out and it ran the same boggy stalling way,, planing to go to dealer to let them fix it, I would like to ride all year round with the quad,,, can they jet it for like 0 degrees to like 60 degrees and then I could put factory jets back for summer?????? I do plan on putting an k&n , and a pure polaris pipe on for summer so I guesse it will change again ??????HELP
riding in the cold
While an expert chimes in (I'm going to buy my first quad), let me tell you not to run your quad like that. Cold air is denser, just like air at sea level vs at altitude (I live at 4K'). If you go from sea level to altitude, or from cold to hot, you're going to run rich, which doesn't damage the engine. But you're running LEAN now, and that's dangerous to the motor.
If you don't want to mess with jetting twice a year, set it up for the coldest temperature you'll be riding, and it'll run fine in summer, although rich (that's the way units usually come from the factory). If you want optimum power and fuel economy, you'd have to rejet accordingly. That's why I'm buying an EFI, to stop messing with carbs. I don't have specifics, such as jet sizes, but hopefully somebody will pitch in shortly.
Good luck.
Good luck.
riding in the cold
There should be info in your owners manual for cold weather carb settings, I would raise the needle one position and increase the main jet one or two sizes. Remove the plug over the mixture screw so you can adjust it also, turning it counterclockwise (out) will richen the idle and pilot circuit but don't open it more then 3 1/2 turns from the seated (screwed in) position. You may need a larger pilot jet for throttle settings 0 to 1/4 if you can't get it right with the mixture screw, this screw fine tunes the pilot circuit. The needle is for 1/4 to 3/4 throttle settings and the main jet from 3/4 to full throttle.
You would be wise to learn how to do this, it's not that hard. You'll save money not going to the dealer so much.
As ELP800 said don't continue to ride it like this (lean) you risk serious internal damage to the engine.
riding in the cold
Actually if you want to know the truth, with all the pollution standards that have to be met now, machines are jetted either spot on for "milder" temps or EVEN LEAN. So, as cold as it has been here in WI, it is running lean. How lean?? Well that depends on if the Preds. are a little on the lean side for emissions or not. The best thing to do is what powerslider said & find someone whom you trust in this area & have them teach you how to do it.
