Trialblazer 250 mods
Old Jan 4, 2005 | 01:00 PM
Foxracer37's Avatar
Default Trialblazer 250 mods
I got a questions about jetting.. Do you replace all the jets? or just 1 specific one? And im getting a Hpd pipe and silencer for my quad and then l8er on a clutch kit and k&n airfilter and then i need to rejet. How fast will i get going with all that one? And Does any one have any experience with a chain tensioner? Are they worth buying?
Old Jan 4, 2005 | 01:56 PM
RAJ's Avatar
RAJ
You will replace the main jet. And the chain tensioner is worth the money...if you do alot of jumping.
Old Jan 4, 2005 | 02:06 PM
thewayout420's Avatar
if you put a hpd pipe on dont wait untill later to jet it,adding a pipe REQUIRES rejetting.you pretty much need to add a clutch kit also,but i guess you can get that after adding the pipe..
Old Jan 4, 2005 | 05:15 PM
Foxracer37's Avatar
But i can wait for a bit to get a clutch kit? im going to get one as soon as i got the money.
Old Jan 4, 2005 | 05:20 PM
BigBadScrambler's Avatar
You may be better off just getting the RCR stage 1 kit. It has everything you need (pipe, silencer, air filter, jets, clutching) with YOUR choice of pipe (including the HPD pipe). $325 with free shipping
Old Jan 4, 2005 | 06:16 PM
ftwflh's Avatar
THis is your best deal .......but if you insist on the HPD pipe you MUST rejet or you will toast your motor.And it will not run any better with the pipe if you dont clutch it could run worse.I tried to detune the clutch in my sons when we first got it and it lost ALL the bottom end without the kit that matches the pipe.
Old Jan 4, 2005 | 07:03 PM
Foxracer37's Avatar
Hey ftwflh How much do those pistons help your sons quad out?
Old Jan 4, 2005 | 08:12 PM
DGScrambler400's Avatar
RCR Stage 1 is your best bet, you wont go wrong with Rick Ritter
Old Jan 4, 2005 | 11:45 PM
mudmaster250's Avatar
the wiseco piston wont really give u a gain in power just a huge gain in reliability. the stock piston is a cast one and will break eventually. the wiseco may let it rev a little more.
the chain tensioner is definatly worth the money even if u dont jump. i hardly ever jump and when i didnt have one i ate through chains and sprockets, now with the chain tensioner and a better chain i havnt had to adjust it even once yet and ive had it on there for 6-7 months now.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
