Sp 800 Clutch problems
Originally posted by: ELP800EFI
Do you know how do you 'shim' the clutch? Would like to know in case of trouble (Dealer is 100+ miles away).
Thx.
Thx.
#15
creeping was minimal, did not really move on the ground, mostly just a term of speech. Most noticed was its hard shifting. wifes 05 sp 700 smooth and easy shifting. Belt was definatly to tight, why im not sure, we put a shim between the back two shivs to loosen the belt. shifts easy now.
#18
Originally posted by: Dragorus
You have to hit the rear brake pedal to shift smooth
Originally posted by: oledad
Any tips on getting the shifter to work easier, mine is real stiff, sons 700 does fine,
That's right if shifting from/to P R or H you are supposed to hold down rear brake.
