I got my Mudlites mount on my C-series wheels & all I can say is...
Old Jan 11, 2005 | 07:04 PM
jefffoxsr's Avatar
Default I got my Mudlites mount on my C-series wheels & all I can say is...
NICE
Old Jan 11, 2005 | 07:58 PM
SPORTSMAN70003's Avatar
I already have 3" wheel spacers all the way around plus it made my front end 2 more inches wider & the rear 1" wider. I do alot of rock crawling and I'm kind worried about it being to wide so I might take the spacers off. What do you think? I know it looks mean with it that wide. Thanks for the compliments.
Old Jan 11, 2005 | 08:00 PM
jefffoxsr's Avatar
I am curious as to what the benefits are to the wheel spacers. Thanks in advance for the answer.
Old Jan 11, 2005 | 08:15 PM
I like the wheel spacers because they make it fill more stable like when you go around a hill it don't fill tipsy, not that it felt that tipsy before . Plus I had those Gators on the front and they would rub the tierods if I didn't have them on.
Old Jan 11, 2005 | 08:18 PM
  #15
jefffoxsr's Avatar
Thanks.
Old Jan 11, 2005 | 11:11 PM
  #16
elkbow's Avatar
I noticed something about your pictures, on the front end your tires are showing a postive camber...i.e. the top of the tire is leaned outwards, mine is showing a negative camber, i.e. the top is leaning inward some....
for more controlled handling a negative camber is required....not sure why yours is positive, since all polaris camber is not adjustable....and are usually setup with a negative camber....
dave
Old Jan 11, 2005 | 11:14 PM
  #17
jefffoxsr's Avatar
Dave is a never-ending source of useful information. Thanks.
Old Jan 11, 2005 | 11:17 PM
  #18
elkbow's Avatar
Jeff, isn't yours the same as mine, negative camber...i.e. the top is leaning in....?
Old Jan 11, 2005 | 11:20 PM
  #19
I will have to check that frist thing in the morning. You say there is no adjustment?
Old Jan 11, 2005 | 11:21 PM
  #20
jefffoxsr's Avatar
Yes, mine has negative camber.
