Solution for winch cable/plowing problems
Old Mar 3, 2005 | 08:14 AM
tyler711's Avatar
Default Solution for winch cable/plowing problems
I would, too, if I didnt need the winch as a winch for when I ride.
Wow I keep getting this thread confused with the other one with almost the same name/topic.
Old Mar 3, 2005 | 12:42 PM
mtpockets's Avatar
i have found that if you don't lift the plow all the way up the cable won't fray and snap. just raise the plow enough off the ground to get around. say 4-6".
if you raise it all the way up. bottoming out the winch, of course all that extra unneccesary strain will fray the cable.
i've plowed about 40 miles on my new ATV and have yet to see any cable wear.
give it a try and save some $$.
-MT
Old Mar 3, 2005 | 12:48 PM
neversunk's Avatar
thats why I like the handle type unit to lift and drop the blade....but I can't get enough height from it to get on and off the trailer....
Old Mar 3, 2005 | 12:59 PM
silverbullet2005's Avatar
I get 15 inches of lift to the bottom of my plow blade due to my 2" front suspension lift and the new 27" mudlites. so ground clearance isn't a problem.
Old Mar 3, 2005 | 02:54 PM
  #15
neversunk's Avatar
silverbullet.....thats 15"with using the winch to lift it you mean? Or is that with a handle type lift?
Old Mar 3, 2005 | 06:46 PM
  #16
tyler711's Avatar
SB2005 uses the winch for his plow.
Old Mar 3, 2005 | 08:43 PM
  #17
simonsez's Avatar
I have been using a $12.00 tow strap from home depot, i cut the hook off one end and wraped it around the winch drum. I did not have to even tuck it in the hole on the drum and have no problems with it going up and down. I've been using this setup since december with no issues. When i want to ride i just put the cable back on and go. Even if i overwind it at the top the drum will just slip and no stress is put on the strap. Try it!
Firefighter400
Oct 8, 2022 06:38 PM
toonces
Oct 19, 2015 02:21 AM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
