99' Trail Blazer 250
I know it will run faster than 50mph.I ride with a 3004trx all the time, and it tops 60mph, and I can hang with him.I used to couldnt till today.I oiled the chain, and cleaned the air filter.Im thinking aobut getting a FMF pipe, to give a few more horses.
Where are you getting your speeds from? I have never seen a 300 fourtrax got nearly that fast. Assuming you mean the trx300, and not the 300EX. My 2000 Blazer does close to 50 tops. Even with a pipe, you will not see to much more on top. Maybe 1 or 2 mph. You will definitly see more bottom end and some mid range though. It will be very hard, if not impossible, to get 60mph out of the T'Blazer with only bolt on mods.
Don't forget to add a clutch kit with your pipe. It will help the pipe and engine get the extra power to the ground much more efficiently.
Alex Rodak
Sep 11, 2015 11:42 PM
craacker
Sep 9, 2015 04:32 AM
