WORK LIGHT PICS
Old Feb 2, 2005 | 11:31 PM
HELLHOUND's Avatar
Default WORK LIGHT PICS
I added a work light here are some pics
PIC1
PIC2
PIC3
PIC4
Old Feb 3, 2005 | 12:28 AM
polaris5610's Avatar
Looks good.
Old Feb 3, 2005 | 12:38 AM
elkbow's Avatar
What....no pictures with it 'on' in the dark?
Old Feb 3, 2005 | 01:51 AM
jimmypsp700's Avatar
Do you sell a kit for that?...Dave?
Old Feb 3, 2005 | 01:56 AM
elkbow's Avatar
no...if I had an older model to use for alittle bit, I could configure one for you....one thing that would be cool would be to make dual backup lights like the 2005 models have, with a switch on the pod....but mount them up on the rear rack....would be easy to do....that would be universal and I would have to only make mounts for the racks which are all the same thickness.....
Old Feb 3, 2005 | 02:03 AM
Sounds good. If i were nearby you could toy with mine.
I need/prefer directions for those kind of things but could probly figure something out.
Old Feb 3, 2005 | 11:13 AM
HELLHOUND's Avatar
This was simple to do bought most parts at walmart (the light is a tractor light 55 wats i think it was around $15 )napa had the rubber boot ($5) for the switch the only thing i had to make was the bracket for the light but im sure you could find something at walmart or nappa i ran the ground to the battery and i took power off the acc. socket it's on only when key is on i ran the power wire in a wire casing (walmart 6' for i think around $5 i needed adout 7' ) i routed it along the left side with the wires for the winch up into the pod took me about an hour and a half
walmart also has a set of off road driving lights for around $20 they are round and smaller and would probly mount up to the rear rack in some of the existing holes
Old Feb 3, 2005 | 11:32 AM
Thanks for the info.
I was thinking of getting some of those lights for my Scrambler!
Old Feb 3, 2005 | 01:07 PM
HELLHOUND's Avatar
Forgot i put a fuse from the hot wire to one side of the sw
Old Feb 3, 2005 | 08:05 PM
silverbullet2005's Avatar
cool, nice pics by the way. I was thinking of doing the rear worklight mod to my 700EFI but have a few other mods I would like to do first. I will probably do it this fall just before winter so I'll have a worklight on the rear for while I am plowing. I may wire up a two wire weatherpack connector so I can remove the light for the off season.
