Busted tranny case....don't that suck?
"Miffed"? I'd be more than miffed. So that plastic "case saver" didn't, huh? Figures. So I guess the rest of us need to go out and fabricate something out of metal. This month's ATVRider magazine has an article on case savers. They show "chain wheels" that are used on some models. I have a chain tensioner on mine, but these look a little different and apparently only contact the chain at extreme extension or compression of the swingarm, and supposedly grab a slingling broken chain. I guess that's the idea anyway. I feel your pain man, now you've got me scared about mine! There's been some Polaris transmission on ebay from time to time, but they changed the design over the years so you'd have to be specific.
rook, also if you decide to change case. there are 2 bushings for the bevel gears. i don't think they come with new case. they are a real pain in the a$$ to get out sometimes and usually end up destroyed if you do. one has to come out tho to get to a thrust washer behind it. thought i had a used 1, but it was for different model, sorry. good luck
#15
Sup RookWV.....we have so much in common man, I'm in Beckley also, (Piney View), 500 Scrambler, and I had tranny troubles TODAY!, I'm thinking mine is not as bad as yours (I hope), will know more at work Monday when I get a better look at it, I think I just stipped the teeth off my front sprocket, where you guys ride at? We mainly run around macknie, garden grounds, out Mill Creek and such. Hope you get that bike fixed, maybe we'll run into each other ridding!
#16
Wow! We're pratically neighbors, I'm down in Stanaford just up the hill from JC's.
ftwflh, too bad....you need to move closer! [img]i/expressions/face-icon-small-wink.gif[/img] I'd float you in beer!
And to think I had been thinking about trading......guess I shoulda done it!
#17
Comon Rook! thats no way to be! Like fiflwh said, it really isnt that bad. I bet if you sit down to the kitchen table with the servce manual for a couple nights, youll be able to do it no problem.[img]i/expressions/face-icon-small-wink.gif[/img]
Id also look into geting it welded... this just may be cheaper than a new case
#18
#20
Talked with a dealer today, he said right around $700 after labor but that's including both halves of the crankcase ($400+). His labor rate was much lower than I expected. He said it'd probably be a couple of weeks in the shop....
I wonder how much I could get out of the wheeler right now being busted? I'm not sure how much I'm liking spending a bunch of money on something I have no intentions of keeping......I had been thinking of selling it anyways
