Polaris Speedometers!!!!
Old Sep 19, 2000 | 10:10 AM
Victor69er's Avatar
HI. I was riding on the weekend through some heavy brush with my sp 500 and ever since the speedometer will not work right. when you turn the key the speedo says "SErd 15" and when i drive up my road about half throttle the speedo is burried down by the polaris logo at the bottom of the speedometer. I will take it to the dealer this week. its still under warranty. Anyone familliar with this problem please help!!!
Old Sep 19, 2000 | 10:18 AM
ChopperBill's Avatar
I know it has a battery to keep its memory, but was just wondering if you would disconect the main battery for a while it would "clear it's throat". I know it works on computurized cars sometime. If the speedo gets hung up at say 30 MPH all you have to do is ride it past that speed and it will start working again.
Old Sep 19, 2000 | 10:45 AM
Victor69er's Avatar
Thanks Bill. I'll try it and let you know what happens. Any other suggestions
Old Sep 19, 2000 | 10:50 AM
Xplorman's Avatar
I remember reading something about that on the Polaris web site. There was a procedure to follow to correct the problem but I can't remember what it was. Do a search for speedometer and it will probably pop up.
Old Sep 19, 2000 | 01:48 PM
Farmr123's Avatar
The newer speedos use an electronic speed sensor. It reads speed by 'counting' the holes in one of the front brake disks as they pass in front of it. Sounds like you might have torn the wire to the sensor or pulled it far enough out of line that it isn't reading properly. You can see the sensor if you just follow the wiring to the front end. Along one of the struts there will be 2 wires, one will go to the hub locking mechanism, and the other to the sensor.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
